Camera alignment frame is too big
Lightburn 1.1.03 (but has been an issue since 1.1)
When framing the burn area for a camera alignment, it’s now trying to use the entire bed size. This might be OK but the UI states that an 8" square is required. The actual frame produces a 13" square image, target to target.
Are you able to use the “scale” setting to reduce the size until it fits comfortably? 8" is the minimum recommended size I believe.
I went through the same thing when i recal’d my camera! Ended up scaling down by half to get in back within the area i wanted. Mine originally went out almost 20" .
How do you scale? I see no option and it clearly says 8" square! My target to target is about 13" when framed.
You can set the scale right on that screen. The 182 you have in theory is 100% or full scale if i understand the calibration factor correctly. if you divide the 182 in half it would be approx 50% scale and get you somewhere in the 6.5" range.
Wow. How did I not see that?!
LOL oversights happen. I recently purchased light and got on the forum yesterday, since my purchase there has been 3 or 4 update in the last few weeks so i have been setting up and calibrating cameras and motor settings to get everything fine tuned to the best of my ability. I have been all over the web and back and forth trying to tweak everything myself. lots of focus points at once.
