Running a Ruida on a 50w Chinese Laser thats 700X500mm.
-cant zoom in during any part of the set up. I press “zoom in” and it does nothing -on the alignment test, i only get the center pattern. The 4 corners dont show up for some reason.
Please help.
The Scale: field in your image shows 252 percent. You should be able to reduce that number to get the diagram to fit in your work space.
This worked although my bed IS 252 and when i frame it, it traces it perfectly but i still had to reduce it.
Thank you.
