have a problem with alignment of the camera on my K40. It calibrated with out a problem but when i do the alignment its all jacked up. I posted a picture of what its doing. This is a camera i got off amazon.
Rick
(Technical Evangelist)
February 24, 2020, 9:24pm
2
Might find this worth a review.
These are the most common reasons for difficulty with camera calibration:
The camera doesn’t need to be on the machine for the lens calibration - It’s ONLY the lens and pattern that matter for this part, and the pattern can be scaled up.
If you do it on the machine, if you have a honeycomb bed, cover it (bedsheet, paper, wood, etc) - the pattern gets misinterpreted as more circles and confuses the software.
The printed circle pattern has to be as flat as possible . Glue it to wood or f…
Thanks i think i got it now. Will try again later.
That looks like the machine is skipping steps when moving between the different marker cuts. Likely your speed or acceleration (or both) are too high.
I got it you were right speed and acceleration set to high.
Thanks
