I finally got my calibration done on my boss1416… on the screen it looks like it should be a square, but it is burning as a rectangle. What would cause this?
What is? Can you show a screen shot of what you mean? (I can’t tell if you’re referring to the camera alignment pattern or a job afterward)
the issue is with the calibration/alignment. Most of the time it says it cannot see it, when I did finally get 9 shots, and tried alignment the pattern comes out as a rectangle not a square, and the screen capture cuts off the front corners (I can not get that far again to get a picture)
THanks for any help!!!
Do you have rotary mode on? Go to Tools > Rotary Setup and make sure that rotary is disabled. If it’s not, it would affect the Y scale of jobs.
My hero! Thanks so much
