Hello,
I have a ATOMSTACK MAKER Laser Engraver AC1 Camera and no matter how many times I calibrate it, the images still are not in the right place. I have confirmed that it is at the 420mm requirement using the pole that Atomstack sends. I am receiving good scores on the calibration and have a bright light inside the enclosure it’s in.
I am using it on an A5 Pro with Lightburn V1.7.01.
Any thoughts? It just ran the burned spiderweb and I did not move the wood or anything, just took another picture.
I would like to add that I had to manually track the pattern since the camera is not picking it up the alignment properly. that’s why you will see some of the pattern off the sheet of wood since it is not picking up the board correctly, I am having to manually locate it.
