In the camera alignment wizard I’m asked to specify material thickness…should I assume this is in millimeters seeing as though LB specifies the overall size of the panel to be lasered is shown in millimeters?
It’s only relevant if you have an Emblaser system, or you’re actively using the Z on your laser. If you focused manually, you don’t use it, and the number is not used by any part of the camera math.
