After I align my camera and go to capture the image it only shows part of the bed area. Have realigned it several times and still does the same thing. Any help would be greatly appreciated,
There must be something wrong with your lens or camera alignment, did you use April tags or the old way of doing it? Did you follow the order of targets in camera alignment?
Try to explain a little more what you are working with and how you did it. You can also search here in the forum for your exact problem, we have had it up many times before.
I’m using lightburn. Used the April tags and did the 1 2 3 4 targets. In the camera control it shows the whole bed but when I do the update overlay it only shows part of the bed like it zoomed in. Using the lightburn 8mp (4k-n) 120 deg.
It’s annoying, but you have to start all over again. Some people experience it, me included, but it works in the end. It takes patience. It’s possible that others can give you better advice, but for me, just repeating the processes worked.
tengo el mismo problem doy calibrar y todo bien hsta hi, pero cundo le doy establecer area de trabajo sno lee mi angulo de cma o ls dimensiones no las lee alguna solucion
