Chuckphd
(Chuck Terra)
December 9, 2025, 9:53pm
1
I have wondered why LB brightness changes don’t stay in affect after re-setting and exiting LB.
so I decided to go into windows and adjust the Camera Brightness and Contrast…
I started LB and the changes were working as set in Windows…
Not sure why LB does not save the Settings values but this is a working solution for me anyway….
Apologies if this topic has been noted before, but … probably needed to be mentioned again….
Colin
(Colin Worobetz)
December 9, 2025, 10:08pm
2
It could be that LightBurn has a hard time determining if your camera is the exact same camera that was connected previously. It’s a common issue with USB cameras that they do not have unique identifiers.
If you export your camera settings, then import them after reopening, I suspect the values will stick. Camera Control Window - LightBurn Documentation
Chuckphd
(Chuck Terra)
December 9, 2025, 10:23pm
3
thanks Colin….. I actually bought my Camera on the LB site to ensure compatibility…. soo….
