After updating to version 1.70 (W10) everything seems to work OK. I wonder if it is mandatory to calibrate the camera again, since I am satisfied with the current settings?
Hi Vinko,
You could take a Export of your camera settings and keep them safe.
Right click camera control window > Export settings
Save it safely then you can and should run a new calibration to make sure the new calibration uses the new Camera code and patterns.
I made a backup of the settings, just in case. With Lightburn version 1.70 I had no problems recalibrating the camera.
