Camera calibration fail
Recently new falcon 2 pro 40 watt , followed the circle calibration card perfectly, , once I proceed to the actual 1-4 alignment burn, it burns it mirrored , I then click the centres in order and finish, image is then corrected in my screen. I then burn some text . However it then is also burned in mirrored , ( as if from bottom, ) only I then update the screen layout and the text magically flips , so on my screen it shows that it is what I want , only the actual image cut is wrong way round . ??? I have tried this setup twice now , and don’t know what I should do ??
This should help identify the issue. Please post a screenshot of your entire Lightburn screen with your project loaded and the Cuts/Layers Panel and Laser Panel visible. Also post a screenshot of the Settings Window (Gears icon) with the Units and Grids tab visible and post a screenshot of the Device Settings Window (Wrench and Screwdriver icon).
Hi Tim, thanks for replying. I managed to resolve that issue, it was literally a few cases of redoing and redoing but saving the origin , I cleared the works and went back to redo all again, and found it working .
In another hitch, not as bad this time though, I started cutting and downloaded a speed/ strength pattern and ran it, that seemed fine,
Then I started cutting some projects and then noticed that the burn on my left to right was about half of the burn too to bottom on each and every cut.
How would i go about rectifying this ?
I made no changes . So not sure what might be causing this
Brand new falcon 2
Do you mean the size is wrong or the burn strength is wrong? Pictures really help visualize your description.
