Camera Calibration Wecreat Vision
ok, as I was trying to calibrate the camera in LB for my 20w vision went step by step with video, I think I messed up I put in the thickness of wood then I put in the wrong power and speed it burned start through the wood. I tried to stop the job, but it kept burning as I was freaking out i turned off machine then turned back on tried to re calibrate it. now in LB it says “already in use” How do I cancel this job so I can calibrate my camera.
Thx
Sandie
If you have not already figured it out, reboot the PC. That will make Windows release the USB port.
If this happens again and you don’t want to have to restart your computer, you can also right-click the ‘Devices’ button in the Laser window to refresh the connection to your laser by acting as a quick “disconnect and reconnect”
Ok I will try this, but it thinks I calibrated and wants ne to align now. When it was messing up it burned out just one part of the calibrate.
