I know its been asked a lot, Im working backwards here… My bed us 1300, and the door is 900mm away , which using trig, gives me a camera angle of 70 degrees.
I cant find a multiplier, so i assume trig will work?
One potential issues with that camera you linked is that the camera may default to a lower resolution if used on a Windows based system. LightBurn’s camera has been factory set to default to the highest resolution, giving you better positioning accuracy.
According to this you’ll need a 120’ lens. My limited understanding is that the ‘lens factor’ is a way to simplify the math - but the Field of View should be the same as calculated as far as I understand it.
I measured the actual image presented from the camera for every camera/lens we sell - no math involved. The camera sensor doesn’t necessarily capture the full breadth of image from the lens, and the FOV is usually measured diagonally, not horizontally.
I am also looking for a camera for my laser. I guess that I need the 90 degree lens (out of stock) for my 400mm bedsize. Highest point for mounting camera is 700mm
Inputs anyone?
@Lightburn when will you get this lens in stock again?
I’m not saying your math is incorrect, I’m saying I put a measuring stick on the ground and actually measured the breadth of the camera view from a known height and computed the ratio, and did this for each camera we sell. If a 120 degree lens is used, but the sensor only covers the middle two thirds of it, you have an 80 degree view.
