I imported a 160 degree Llightburn camera which was well packaged and really straightforward to install and calibrate thanks to excellent installation procedure. However, could the purpose/ function / use of the width, height, x shift and y shift in the camera control option screen be given as I do not see any guidance on this in the online documentation.
They are for fine tuning the width, height, and centering of the camera backdrop to correct for any inaccuracy in the result. Get as close as you can through the normal marker tagging, adjust (and click save) if necessary.
