Camera Flipped on engraving not on overlay
Hi,
I noticed a few posts regarding flipping of the camera, but after doing the lens and camera calibration, the laser is burning backwards.
Can someone help me with this? Even though the numbers were flipped in the camera preview, i did click them in order (1,2,3,4).
Any suggestions? or else I’ll have to produce all my work backwards to get things looking right!!!
It looks like the target marker engraving itself was flipped, so you most likely just need to adjust your ‘Device Origin’, found in your ‘Device Settings’ (‘Edit’ > ‘Device Settings’). If you’re using an Ortur, it should be set to the bottom left.
