Hi, I have this laser 1000x600 mm. Laser`s top is not in the center and middle of the table, but very behind, distance from top to bottom is 900 mm, my question is whether I can use Ligtburns camera type 8mp W 120 gr. It is set to a minimum of 444mm, but will this camera be able to be used for “my” distance which is 900mm?
The 8mp-85 would be a better choice - it will see the whole bed at a height of 711mm, much closer to your 900mm mounting height. If you used the 120, it would see MUCH more than you need, so you’d be wasting a lot of the image on stuff you don’t need it to see.
