Camera freezing and alignment totally off since last update
Camera is a LB 5mp 140 deg used with a ortur laser master 2. Since last update it freezes I have to switch back and forth from web cam to LB some times works others I have to close out LB. Also alignment is off no matter what I do used to fill the whole work area frame now it dont (see picture)
Did you redo the camera alignment and reuse the previous marks, by chance? That could easily explain the scale issue.
For the camera locking up, nothing in the camera code has changed for a while. Did you add an extension cable, or change something with how it’s connected?
