I had avoided the camera for a long time due to all the complaints I read. I figured what I got out of it (usefulness) was not worth the hassle. Then Oz (Jason) posted some info about the new install process and I got curious.
I only planned to use the camera for matching up designs with assorted pieces of scrap material. Not expecting to use it a lot, I selected about the cheapest USB camera I could find that might work. Then I added a mount adapted to my setup where I could drop the camera down to use, then flip it out of the way when running. I could do the setup without having close the cabinet. My design was based on work by Rube Goldberg.
Camera: Foscam 2K 4MP Drive-free USB Web Camera ($22 Amazon)
Only at 2 points did I struggle during the camera install process in Lightburn. [1] During the lens calibrate, I learned moving the April Tag sheet was not necessary, and more than 5 images does not improve the % value (83%) displayed. [2] Before starting the Calibrate section, have the laser powered up and Homed. There is no way to do it when you get to the part that burns the targets on your material. You can set the speed and power settings at this point.
Comments:
- The camera view is good in the Overlay but upside down in the Camera View. I don’t care.
- The Overlay image has a reverse pincushion appearance, but whether or not that matters is to be seen.
- I could not find a switch to turn off the Overlay in the drawing. The black squares you grab to adjust your drawing size and position were invisible over the dark honeycomb. I finally realized the Opacity Slider was what I needed to use. Brilliant control!
- I drew a rectangle, then moved it over the #3 April Tags. As best I could, I put the rectangle bottom line on the tip of the target symbol, then hit Run. I was totally satisfied with the T intersection I created.
- I do not know if I can get 0.5mm positioning accuracy claimed by some, but it is more than enough accurate for my needs. For a $22 investment.
