Hello, I’m having issues setting up my camera in Lightburn as it’s not appearing in the “calibrate camera lens” section.
I’m using a Chromebook, launching Lightburn - Version 1.4.00 - via the Penguin terminal. The camera is the Sculpfun Cam500, recognized by the Chromebook and functioning as a normal webcam, but it doesn’t seem available in Lightburn through the terminal.
I’m not familiar with Linux at all.
Has anyone dealt with setting up a camera in Lightburn on a Chromebook yet?
Yes, I know that Chromebook are not supported. I use Lightburn in this Chromebook since several months and never had a problem - except for the camera issue.
Linux 11 / Bullseye
Intel Pentium CPU N4200 1.1GHz
When i connect the Sculpfun S9 with the Chromebook there is a pop up for a new USB device and the button “Connect with Linux” and only after this the laser is available in Lightburn.
When I connect the camera there is no pop up to connect with Linux, although I can use the camera in the Chromebook.
Ist there another possibilty to connect the camera to Linux without this pop up message?
