I need some advice on camera alignment. using the wizards I get nice low readings on the lens calibration, and have no issues with the alignment , but laser is a good 50mm off of item under camera. Have tried to use the laser position tool but once again 50mm off , either there is an issue in the software setup or I am doing something wrong more than likely the later. what I cant understand it has been fine up to a couple of days ago, and has not been touched. Has anybody else had this problem. my work piece is 400 w x 200 h I need to run a line 10mm all round but seeing the laser is so far out my 10mm starts 50mm in from the edge. using GRBL and absolute coords
