Scored no higher than .18 during calibration (had some as low as .07)
Lasered a 10mm x 10mm square and measured with calipers, came out right about 10mm x 10mm
Performed “Calibrate Camera Lens” and “Calibrate Camera Alignment”.
As you can see from the attached image, the text that is burned does not match the text that is digital.
I calibrated (lens and alignment) 3 different times, each calibration was progressively better, without change in these results.
Hello,
Just a suggestion, what happens to your backdrop if you remove the -.03 width that is showing? Those controls are for dialing in the the backdrop to match up what your layer is displaying.
Cheers
I knew that was going to come back as a question the minute that I posted this. It makes no difference really. I just redid the burn and got the following results:
I also have been trying to use the width, height, x shift and y shift adjustments to make the overlay match the artwork. Which I can do, but then on the next burn and refresh of the overlay, they don’t match again
I used a piece of cardboard (1/8") to burn my alignment targets, the piece in the image I provided is also 1/8". So, I am under the assumption that they are at the exact same height (the focal length of my beam). Tonight I will double/triple check that these are the very same.
