Camera issues with LB camera
Have an OMTech 130W AF3555 Co2 laser, bought the lightburn 8M 85deg lens. Went through the camera lens calibration and laser cal but i can either get the corners lined up with what i burned and the center is off about 5-8mm to the right. Or get center lined up with the burn but then all 4 corners are off the same 5-8mm to the left. Have done the cal with the lightburn camera profile and a complete cal using the dot card. At a loss. Would the 120 deg lens be better to get all corners lined up and center lined up with the laser?
Thanks, Dennis
