After setting up the camera, (Thunder laser nova 51, 100 watt. Camera mounted to lid center.) I used the move here from the tool list and pointed at the #1 setup target just used to set up the camera, and my laser head located itself 3-1/4" above the target (the X axis)?
The Y axis location seemed fine.
When I pointed to the #4 target the laser located itself about 3-1/4" below the target.
It does go to the center target and seems pretty close.
Is there a process that will help me dial this in?
I’m planning on using the trace function pretty often.
Thank you.
having the same issue!
