Camera mode selection
Per the documentation for my camera, it has 8 different modes. Is there a way to affect which mode LB selects?
What do you mean by “modes”? Your wording isn’t clear.
Well, that is the term that the camera uses. By mode it means resolution and scan rate.
Check the Settings window, near the bottom. If you are using the ‘Custom’ camera library, LightBurn automatically chooses the highest resolution. If you are using the ‘Default’ setting, it just uses the default resolution set by the camera maker, and we don’t have the option to change it when using that library.
