Camera not working in LightBurn 1.7.03 and Ubuntu 24.04.1 LTS
I installed my new camera but it is not working. when LightBurn starts shows the following message:
(lightburn:845063): GStreamer-WARNING **: 02:50:54.096: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgsttcp.so’: /lib/x86_64-linux-gnu/libgio-2.0.so.0: undefined symbol: g_assertion_message_cmpint
(lightburn:845063): GStreamer-WARNING **: 02:50:54.098: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstqroverlay.so’: /lib/x86_64-linux-gnu/libgio-2.0.so.0: undefined symbol: g_assertion_message_cmpint
(lightburn:845063): GStreamer-WARNING **: 02:50:54.100: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvpx.so’: /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvpx.so: undefined symbol: g_once_init_leave_pointer
(lightburn:845063): GStreamer-WARNING **: 02:50:54.100: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstgdp.so’: /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstgdp.so: undefined symbol: g_once_init_leave_pointer
(lightburn:845063): GStreamer-WARNING **: 02:50:54.102: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpegtsmux.so’: /lib/x86_64-linux-gnu/libgstmpegts-1.0.so.0: undefined symbol: g_once_init_leave_pointer
(lightburn:845063): GStreamer-WARNING **: 02:50:54.104: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgsttaglib.so’: /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgsttaglib.so: undefined symbol: g_once_init_enter_pointer
Error: cannot create camera service, the ‘camerabin’ plugin is missing for GStreamer 1.20.
Please install the ‘bad’ GStreamer plugin package.
Socket write error: “The remote host closed the connection”
Can you Help me ?
Ubuntu’s Gstreamer version is 1.24.2:
dpkg -s gstreamer1.0-plugins-base
Package: gstreamer1.0-plugins-base
Status: install ok installed
Priority: optional
Section: libs
Installed-Size: 2455
Maintainer: Ubuntu Developers ubuntu-devel-discuss@lists.ubuntu.com
Architecture: amd64
Multi-Arch: same
Source: gst-plugins-base1.0
Version: 1.24.2-1ubuntu0.1
Replaces: gstreamer1.0-plugins-bad (<< 1.15.1)
The webcam works, I get a camera image with Cheese app
I have the EXACT same problem … and I also used Cheese to confirm it works.
I cannot get the inbuilt webcam to be displayed in the config … although it lists all the cameras attached.
I just tested and LightBurn-Linux64-v1.7.03.AppImage allows me to calibrate the cameras. It’s the installed version from the LightBurn-Linux64-v1.7.03.run that cannot see cameras.
I also added my user to the video group.
I came here to post the same answer: it works perfectly using the AppImage. I’m using an old smartphone with the DroidCam app (I threw away my old webcam, thinking it was incompatible since it only showed a black screen). However, I’m using Linux Mint, which is said to have compatibility issues with GTK, but with the AppImage, it’s working flawlessly.
Distro: Linux Mint 21.2 Victoria base: Ubuntu 22.04 jammy
Kernel: 6.8.0-49-generic x86_64 bits
Desktop: Cinnamon 5.8.4 tk: GTK 3.24.33
wm: muffin dm: LightDM
