Camera overlay not working 2.1.3
just installed 2.1.3 set up camera did calibration that all worked perfectly ,click update overlay nothing happens restarted laser and LB still nothing
Your workspace does not match the image shown. Have you used a different machine bed size for alignment than your physical machine has?
no my machine bed has always been this size, i had camera set up in think it was2.0.5 havent used laser much of late , so not sure whats happening
…aren’t those 2 different geometries in your image?
Another problem (in my opinion) is that you have adjustments in % and mm in X and Y, which indicate a non-ideal lens correction.
what do u mean dif geometric can u show me what ur meaning. camera was working ok in older version. all I did was do new calibration . when I opened new version it askesd if I wanted to import old camera settings. I clicked yes. it had orange triangle thats why I did recalibration
i have never been able to get them the same way on the screen home is bottom left in workspace
i have camera that is made for my laser from manufacture and positioned where they show it is to be set
i have spent hrs trying to get them same way, trust me it is confusing looking at them that way preview one way, work another and than if i look at laser from computer cause of position in shop it is another
those are numbers it spat out i didn’t adjust them , i know your trying help , but it gets rather frustrating at times , everything working fine than boom it doesn’t
ill delete the camera setting that imported from old version and do fresh install see what happens. might even do fresh install of laser as well just for the hell of it
