Camera preview only updates with motion
I have just upgraded to version 2.0.01 (from 1.7) and the camera is weird. First of all the preview only updates when there is motion riught in front of the lens. I wont update if anything is moving on the workbed. I tried the fallback system too and that was the same. It has kinda worked once when it was set to 10fps however the preview was glitching quite a lot so I had to keep refreshing the overlay until I got a good snapshot. The camera was fine on 1.7 yesterday. I use the camera feature nearly all the time so this is very frustrating
Hello Leslie
On LightBurn 2.0 a FPS setting was introduced that might cause the issue you are experiencing.
Navigate to Edit > Settings > Camera.
Try raising the FPS higher than 2.5 and 1.0 default
Good afternoon. I have tried this from frame rates anywhere from 5 upto 24fps and still no luck. It still only updates the camera if there is major movement detected right in front of the lens like i waqve my hand in front of it… which defets the object of the camera cus all I can take pics of is my hand lol
