I printed the dot pattern out but Lightburn does not see it. I tried moving it around, but it doesn’t help.
Can you take a screenshot of LightBurn where you’re getting stuck?
From what I can see there are a few apparent issues:
- The pattern is likely too large for the given area. Either increase the distance or print smaller.
- The pattern appears to have something else printed on it.
- There’s a lot of clutter near the pattern. I’d suggest clearing out any obstructions and working on a consistent background.
Ok I’ll try that. The other pattern is something I burnt into it. What size should i size it to.
You should be able to easily fit a 3x3 grid of the patterns into a single capture size. So a bit smaller than 1/9 the size of the image capture.
Thank you very much. It worked.
