Camera selection causing crash
Yes, it’s possible. The code looks for things that appear to be circles, and there are a lot of them there. The best approach is to cover it with a sheet or blanket. The camera doesn’t even have to be mounted in the machine for this part.
Okay, I realized I used the other side of this panel on previous attempts… I think the camera was picking up all the holes, as you mentioned. I flipped it back and ran it again and no issues. THANK YOU!
I never even considered that, but yes, that makes sense.
If I may ask another question - I am happy with the camera setup and calibration - however, now, for some reason, when I select “Window” then “Camera Control” — there is no window that pops up. It was working a bit ago and now it does not. I restarted the software, the laser, and the camera with no success. As a test, I clicked on Camera Calibration again and Lightburn sees the camera there.
Re-launch the software while holding the Shift key, or go to Window > Reset to default layout. Sounds like your window might be out of the display.
Fixed it, thank you
