I have a OMTech MF2028-60, working area is 20x28. Minimum clearance with lid closed `11 inches. When i put these specs into the camera selection i do not see a camera that has that minimum mounting height. What are my options or am i missing something here?
I assume your bed is 28 inches wide and 20 inches tall. If so, make sure you’re putting in the width first, then height into the tool.
Also, typically you’d use the camera with the lid open, not closed. You had me a bit confused with your description of minimum clearance. The camera selection tool is indicating minimum height required. So I would have expected the distance measured to be the actual height or the maximum height available.
