trying to set up my camera with my new ROLY LASERMATIC can not finshin the setting gives me errore no image capture using the recamanded dot sheet show 0 image any one out there can help to see whatthe probelm is .
Thanks
Not enough info to provide feedback.
For starters, which camera are you connecting?
USB 2.0 or 3.0 connection?
Is the camera capable of streaming video?
LightBurn only supports the use of UVC-compatible cameras.
The USB video device class (also USB video class or UVC) is a USB device class that describes devices capable of streaming video like webcams, digital camcorders, transcoders, analog video converters and still-image cameras.
Thanks Steve for get back to my question no my camera is not capable of streaming it came with my new laser machine ROLY MK2 20W with just USB connector .i did flow the instruction on the manual and also watch some video on you tube but still cloud not set it up .
That means as best I can tell from what I’ve read, that this particular camera will not work for you in this application.
