I am trying to use the camera trace function and then cut out exactly what I just traced exactly where I just traced from but when I attempt to do so the laser moves to a completely different position and cuts there instead. What am I missing here?
How far away is âcompletely differentâ and is the attempted engraving oriented correctly (pointed in the right direction)? Also, please let me know if the object you traced is symmetrical. if itâs the same left to right I canât tell if itâs reversed.
Depending on how far away âcompletely differentâ is, Camera Alignment may have been overlooked or the camera could have been bumped or moved after calibration.
Please repeat the Camera Alignment procedure in the docs.
When you open the Camera Control window in LightBurn, please click âSave Settingsâ before proceeding with Alignment. It might be wise to have a fallback position just in case.
