Hello,
I connect to my Omtech 60W laser running Ruida controller via TCP/IP. Is it possible to view the camera via this connection?
Hello,
It is not possible to use TCP/IP cameras at this time, though it will be in a future release of LightBurn, from camera to PC.
The connection to the Ruida is only used for data transfer to the controller - not for passing camera signals.
Figures it couldn’t be that easy. Thanks Colin.
This is a hack to the PI bridge… It does work, but is pretty heavy data load.
If it’s using a USB camera, you can’t get the TCP/IP address. But if it’s a IPCAM, then there’s a way to access it.
