Hello, I’ve purchased a used camfive laser and opted for lightburn instead of coreldraw. It has a Ruida controller but when I plug my usb into the laptop and laser for setup Lightburn doesn’t find my controller. Is this normal? I know I can enter the information manually but really expected it to find this particular controller seeing that its so popular… or, am I doing something wrong in the process?
What is the model number of your Ruida controller?
Have you tried installing RDWorks to see if that is able to work with the laser?
These are a couple of first steps so you can take while you are waiting for the real customer support team to come online.
The CamFive machines do not use RDWorks. They use a Ruida controller, but it’s got different firmware in it from Yueming Laser. They use SmartCarve by default. I’ve got a 4032K that’s working great with LightBurn. However, I’ve never run it via USB, always done Ethernet. Grab that Ethernet cable from inside the machine, plug it in and config an IP Address in the machine and your computer. MUCH more stable, no drivers needed, and WAY faster as well. That may fix you up.
I got it, Lightburn found the device. Thank you both for the help.
