i have a new Falcon 2 40w laser and i am trying to cut round holes in cardboard but the holes come out misshapen
One of your belts need to be tightened. I had that issue as well and the belt on the right side of my laser had to be adjusted
can i add a image to this post?
You can upload an image.
While you’re making sure the belts have the proper tension, check all of the tiny setscrews holding the belt pulleys onto the motors: in all likelihood, one screw is loose.
Although this guide is for Sculpfun lasers, you’ll recognize most of the parts and the problems & solutions are similar:
thanks for the help
