I just bought the Ikier K1 Pro 24w machine and Lightburn cannot auto-detect it. However, I can set it up manually and run it. I did this by doing a manual setup and choosing GRBL-LPC. However, it doesn’t seem like all of the setting are right as the machine doesn’t seem to be using nearly as much power as it should be able to.
Instead of jumping through a lot of hoops to try to figure out all of the setting details, I thought it might be worth asking this community if there is someone else out there with this machine that could export the settings and send the file.
If it’s as easy as that, which seems to be the case based on Lightburn’s software instruction, I honestly don’t know why they don’t have a library of these files to download to begin with. I’m sure there are tons of lasers out there and they can’t cover all of them, but Atomstack/Ikier seems to be an older and more established brands as diode lasers go.
