Is there a way to disable the “Auto Focus” button in LightBurn. I have installed a 4 inch lens so to be safe I would like to disable/remove the chance of accidentally hitting that button.
I believe if you turn off the Z Axis control in Edit/Device Settings, it should disable auto focus, as LightBurn should have no Z control then.
Thank you, but I already have Z axis disabled and “Focus” button still will cause the Laser bed to move. BTW, the only thing that will stop it, once started, is the emergency stop. Clicking the “Stop” button does nothing.
Odd that there is a “disable Start button” but not a “disable Focus button”
I appreciated your time, and suggestion.
