I have went through the book and could not find how to darken the lines of my project the way I see the lines is very dim.
It looks like you need to turn on the Output switch in the Cuts/Layers window. If that’s toggled off, the layer will be faded in your workspace.
Thank you also when I have the item selected the moving lines are a bit blurry
If you temporarily set that layer to FILL, the dancing outline will not be so hard to see. You can also set the background to a darker shade if grey in the WINDOW settings.
I like the dark background and high contrast grid lines.
And be sure you have the FILL layers set to display as filled
