Can I create a new project while one is running on the laser? How?
Launch multiple instances of LightBurn. Then run the job on one while you’re designing on the other.
Or you can just keep designing on the instance that you’re running the job from. The elements in your workspace can change once you start the job. I usually don’t do this in case I need to rerun elements of the job, however.
