As subject says, I have drawn a small rectangle within a larger rectangle to the metric dimensions of a wall cover plate. If I add text I want to engrave to this, in the exact location on the rectangle. Is there a way to ignore output on the rectangle but still use the rectangle as a reference to where exactly I want the text engraved?
Does this solution work for you?
If that rectangle is never cuted or engraved, you can assign a frame to it by selecting the rectangle (with selection tool) and then clicking on “T1” or “T2” in the layers bar.
It doesn’t even need to be one of the two tool layers. Any layer with output disabled can be a defacto tool/construction/alignment/reference/instruction layer.
So if I just set my lines not to output on the rectangle, but i have the text on the rectangle, the software will tell me laser the location of where i want the text on the “ignore output” rectangle?
Hello everyone that responded. Setting the rectangle to the tool layer worked like a charm. Not sure why Xtools cant have this in their software, but from now on I will be learning Lightburn. Thank you all!
