Can I engrave material around an image?
I may be overthinking this and I hope I am. I am engraving a silhouette of a horse inside an outline of a state on a yeti cup. Can I engrave all the material inside the state lines without engraving the horse? So the horse will remain the same color as the cup while burning the material around it. If this is possible how would I go about that?
Are they SVG files or other?
They were svg but I traced them in lightburn.
If they are SVG you put them on the same fill layer and drag into position. Overlapping SVG’s on the same layer turn negative where they overlap. .
That’s it! I think that’s the answer I was looking for. Thank you very much!
