Can I engrave then cut out?
Hi all, I’m new to using Lightburn and just figuring everything out as I go.
Is it possible using the program to say, engrave coasters and then cut them out?
Sorry in advance if this was a topic already discussed. Thanks!
Yes, that’s one of the standard functions of LB. This is done using layers, and layers are usually processed after each other. Since this is a very basic question, I recommend going through the basics first:
Awesome, thank you, I appreciate your help!
Put each different process on a different layer. Then arrange your layers, usually you want your cut layer last.
How you group and prioritize them will change things.
Always run a preview before you start.
