I would like to be able to frame out the mustard colored box (see pic) with the output turned off so that it doesn’t print. I just want to print the blue. I haven’t had luck with this. Is there a way to do this?
Half-way down your Cuts / Layers window there’s a left-right slider.
When you slide it to the right you’ll see switches for Output, Show and Air.
Turn the switch on the C13 line under Output to off and this will turn off all the layers and sublayers on the C13 (mustard colored) layer.
Preview it in the Preview window in LightBurn to confirm that it will engrave as expected.
Please capture the preview window and share the image if the art does not produce as intended.
