the way I want to mount the camera, the wire comes out the left side, but this ends up with the image rotated 180 degrees. Is it possible to change that in LB or do I have rotate the camera 180 degrees to get the image correctly setup?
Also, th image quality is pretty poor. I’m trying the focus and it’s as clear as I can make it. I’m hoping that the calibration and adjustment fixes this.
The view in the preview window will be in the orientation it comes from the camera, however the background capture will be correct, regardless of the orientation, as long as you tag the numbered markers in the correct order.
“Pretty poor” is subjective - can you show a picture?
