Can I run two versions of LightBurn on Mac mini for diode and fibre lasers?
I purchased galvo license and now I want to buy a Ortur LM3 20W as well. Can I run both lasers on the one version or do I need to buy again for the diode and run two different forms of LightBurn on the one computer?
Thanks in advance
I think the default package contain or is grbl, so if you have a fiber or co2 it should also support grbl.
You can run multiple instantiations of Lightburn, but the software is the same… fiber, co2 or grbl…
May not need or want to complicate things…
Thanks for the reply, so I can run both on the same installation, just indicate which laser is being used?
The device you use specifies the laser.
You will need to create a separate device for each machine.
Thank you for all your help Jack!, I will
