Just wondering if these settings are optimal. All im doing is basically cutting masking tape with this so I can paint. If I can speed this up at all itd be great lol this is for roughly a 15x16 in area. It is usually around a 9-9:30 hour long burn.
A couple of things I’d suggest looking at:
- I suspect you could dramatically reduce the DPI settings for this, especially if you’re using this just as a mask. The reduction of lines will directly correlate to reduction in time.
- If you’re not losing quality you may be able to increase speed and power to suit.
- You could potentially explore converting this to a vector and experimenting with flood-fill or offset fill. This may not necessarily get you a speed boost and there may be some burn quality issues to overcome but another tool to explore.
