For example, put an object on the bed, select some function, and lightburn makes an outline vector of that object? Our ‘slowforge’ could do that, but almost never used it - but I’ve an idea in my head that would be amazingly easier for me to do if this function was available. Hell, it might be, I just didn’t look in the right place?
Thanks in advance
John
Thanks, didn’t think to look there!
Ok - this could use a bit of work… would be nice if we could select the area of the camera to capture. Also it has issues when trying to trace a 3d object, with shadows.
I will try to outline what I’m trying to capture on paper. FYI I’m trying to trace an object so I can laser a jig… ![]()
John
As far as I know there’s no way to selectively capture the image but you can selectively choose areas of the image to trace.
Well, my oh my - my bad. I did not see that, as it’s not textually noted in the trace box. But yes, you can indeed select the area of the camera that is your target! I am once again humbled by the capabilities of this here software.
