Using Lightburn, I can get laser 1 to fire, but not laser 2. I suspect it might be related to cut settings.
First, I have two heads configured, and as you see, Laser 2 enabled:
When I open the Cut Settings editor, I see it’s set to Laser 1:
Therefore, I click to Laser 2, and press OK:
However, when I open the Cut Settings Editor again, it’s set back to Laser 1:
There is no instance when I open up the Cut Setting Editor, and it’s set on Laser2, instead of Laser1, so I’m thinking this is the issue?
I can cut on Laser2 using RDWorks, so I know it works. Your thoughts? Thanks,
Tim
