The current alignment picture is a cross hair with 2 of the quarters engraved. Is there a way to add an option to not engrave? My camera is at a steeper angle and it is hard to tell where the lines cross perfectly. If it is just a simple crosshair, it would be a lot easier to see.
To be clear, you’re saying you have a hard time seeing this:
But you think this will be easier?
I can’t picture a situation where this would be true - the reason the filled areas are there is because they’re much easier to see, especially if things aren’t perfectly focused or lit.
yes, the 2nd one is what I would love to have. I find the engraved area’s depth makes it hard for me to see where it starts and end. I tried to focus my camera as much as possible, but between the slight bluriness and the engraved area not being as sharp, I have a hard time finding the center.
If the engraving isn’t sharp, you likely have a different problem.
The camera targets pattern is a 180mm square, centered on your page, scaled by the scale amount. If you draw a square that’s 180mm, then scaled by whatever scale you use in the camera alignment wizard, you can skip the cut and just use your square.
Can you explain this a little big more. Are you saying draw a square on the wood that is 180*1.75(my scale factor) and use the corner of the square for the calibration step?
