The cut order does not change when I move the layers up or down.
Please share screencaps of what you are observing. I am not seeing the same as you describe. Here is what I observe when changing the ‘Layer’ order. Black layer set to ‘Fill’ runs first. I then change the order and place the blue layer on top, before the black one. Note in the second image, the blue ‘Line’ layer cuts first, then the Fill. ![]()
It was user error by me. Once I had turned on ‘Optimize Cut Path’ in the laser menu the reordering of my cuts worked perfectly.
