Hi,
We are having a hard time getting the camera to work properly.
We bought the 90° camera (unfortunately the order, #13050, does not say if it is the 8MP or 5MP and I forget) and have not had any usable results so far.
The laser bed is 800x1100mm large and the laser was mounted at ~745 mm height. The height is not as much relevant as loosing a bit of the edges of the laser area is not our main concern.
I have not yet been able to achieve good scores when setting up the camera adjustment.
I believe the problem is focusing as can be seen in the images below:
These were taken on a Win10 PC
When for testing purposes I moved the camera to about 350mm the image became clearer but as can be seen the outer parts of the text are still not in focus.
This is our setup:
And these are the scores on a Win7 PC:
What can be done to improve our situation? A camera with higher resolution? A wider field?
Thanks ahead for your support.
